Katsarayuki
- Joined
- Oct 29, 2017
- Messages
- 2
- Points
- 1
- My Device
- SPro
Got a used Surface pro a few days ago. The only things I installed were office, panda antivirus and manga studio 5 ex.
Everything was working fine, turned it off last night and when I returned to work on it this morning for some reason it booted in automatic repair mode.
It failed and is stuck on an automatic repair loop now. I've spent all day trying to fix it to no avail.
Refresh doesn't work. I can't reboot into safe mode as I don't have the keyboard, though I tried doing so through the command prompt unsuccessfuly. I also used the command prompt to disable the automatic repair mode but it did not work and still stuck in the loop.
I don't want to try and reset it as I have the one file from what I was working on which had a lot of effort invested into it.
Can anyone tell me how to solve the loop problem, or even just how to recover that one file when you can't boot up.
Obviously not like a laptop where you could just take the HDD out to get to it that way. If I could get the file I'd be really happy, so of anyone can assist I would be eternally grateful.
Thank you
Thank you
