Oliverlloyd96
Hi all, I bought this device about two weeks ago, I love the device but the battery seems to drain quite quickly. I contacted Microsoft surface support and they recommended that I went back to windows 8.1 then go back to windows 10 as there may have been a bad download the first time, I have had windows 10 for the last few days and the battery level seems to still be falling quite quickly.
While browsing the forums earlier, with just one tab open on edge, and brightness at 0%, at 19:59 the battery level was 29%, then at 20:14 the battery level was 21%, the device also felt quite hot only doing a simple task, does this seem right? Are there any updates/ software to fix this? Or is it a defective device?
Thanks, Oliver
Thanks, Oliver
