Is there a way to keep desktop items running in the background?
Ben Freedman
Howdy...
I have some desktop apps that will run whilst onscreen, but when I switch to a MUI app, they pause or stall...
Is there a way to have desktop apps keep running in the background while other MUI apps are in the foreground?
Thanks!
Best,
Ben
When you say some, which ones are you talking about? The ones I have work fine in Metro and can even have both desktop and MUI versions running simultaneously.
Any desktop apps I run continue when I switch to a MUI app.
We need more detail in order to be able to help, as you are not seeing normal behaviour.
For example, uTorrent.... Runs perfectly whilst I have the desktop showing... When I switch to a MUI App (Metro Media Player, for example), after a very short time, uTorrent will stop downloading. When I switch back to the Desktop, uTorrent has a download speed of zero.
Then, as I sit on the desktop, it'll resume and begin downloading again...
Thoughts?
Best,
Ben
