Orginal Surface Pro video output
Arizona Willie
Mesa, Arizona
I tried the Chromecast and it worked but the delay made it unusable.
I ordered an adapter but it apparently doesn't work. Can't get the video out to my monitor no matter what I do with the settings. I tried a known good HDMI cable but it still didn't work.
Awhile ago I found a gizmo still wrapped up in a plastic bag that looks like a mini-USB to HDMI adapter.
Don't know where it came from.
I'm wondering what this would be used for.
Don't see how I could use it on the Surface because it has a full USB connector.
Any ideas?
It might have been a micro hdmi to hdmi adapter. It's about the same size as a mini usb.
I found that you have to get a decent quality product for it to work as it should, I bought my Display to HDMI unit from a good local computer shop and a good quality HDMI cable, never had any problems since, plug it in, switch on monitor/TV and all works every time.
Could be, I suppose. Don't see any place to plug it in to the Surface Pro.
Guess that's why it's still in its plastic wrapper.
That's because you can't plug it into the Pro/Pro 2 - they both use MiniDisplayPort as a connection out. The Surface RT and Surface 2 do however use the microHDMI.
I recently got a cheap MiniDP to HDMI which has worked perfectly so far.
