Problem with Visual Studio and SQL connection string on SP3
ecustom
I'm having a problem running a VS project using a SQL connection string on the SP3 . I do not have this problem on the desktop using the same connection string. I was curious if anyone else had this problem and how it was corrected.
Using VS2012 and using this connection string on the desktop:
"Server=myServer\myInstance;Database=myDatabase;Trusted_Connection=True;"
No problems on desktop but when run on the SP3, I get a SQL exception (instance-specific error).
If I change the connection string on the SP3 to "Server=myOtherServerWithoutInstanceName;Database=myDatabase;Trusted_Connection=True;" then the connection is accepted and the VS project runs just fine.
Is it a setting on the tablet that needs to accept instance names in sql server?
Welcome to the forum
Since this is more of an app issue than Surface specific this is getting moved to the x86 app section of the forum.
I'm not sure if it is an app issue. Why would this problem occur on the SP3 but not the desktop?
Update: If I publish the app using Visual Studio on my desktop, and set the connection string to myServer\myInstance, then I can run the published app on the tablet. But if I open Visual Studio on the tablet, then try to run the app thru VS and connected to myServer/myInstance, then the sql exception occurs.
Using VS on the tablet, if I change the connection to myOtherServerWithoutInstanceName, then the app will run thru VS successfully.
Other apps connected to myServer\myInstance on the tablet run successfully. OK, I agree this is a clue that it might be an issue with the app and not the tablet.
I was just curious if anyone else had a similar issue and how they corrected it.
