SP3 + IE11 + Low resolution external monitor = scaling disaster
SteveMac
Hi All,
Hoping that you can help me with a rather frustrating issue I'm seeing with my Surface Pro 3.
When I use IE11 on my 1920x1200 external monitor, the window elements/menu bars/etc "scale up" to a massive size, looking stupid.
When I use either Firefox or Chrome, they don't.
Screen shot attached might explain better.
To fix this for other apps I just modify the "Disable display scaling on high D PI settings" check box on the Compatibility tab in the file properties. Trouble is Internet Explorer has no such settings.
** The only reason that I really want to use IE11 is the lack of smooth scrolling available in either Firefox or Chrome **
Any ideas?
Can anyone offer any suggestions on how to stop IE11 from appearing comically large on my external 1920x1200 monitor?
Thanks!
How is your scaling set.... Slider or Let me set a DPI Setting for all Monitors?
I've tried all settings, including full reboots in-between, yet when I move IE onto the lower resolution monitor, it is massive.
Test 1 - Selected "Let me choose one scaling level for all my displays" with 150% scaling = IE size issue
Test 2 - Un-selected "Let me choose one scaling level for all my displays" with 150% scaling = IE size issue
Test 3 - Try various scaling sizes, still same issue
