faline-art
Hi all!
I have a 2015 Surface Book base model, 128gb SSD w/ integrated graphics. Updated Windows 10 on Oct 31 2017 to what I assume is the latest update, 16299.19. Since this update, I'm having a strange issue with my Surface Pen 2017 model. When I use PaintTool SAI ver. 2 build 8.20, the pressure sensitivity with the pen seems to be off. Trying to draw light lines is basically impossible: They literally don't show up on the screen at all. Only when I apply moderate to hard pressure will my lines appear. And this also applies to starting off a line soft and then increasing pressure. The line will only begin once I add pressure. Once it recognizes I'm trying to draw though, the pressure sensitivity seems fine, and it detects the amount of pressure I'm putting down like normal. I tired re-syncing the pen to no avail, and I'm at a loss as to what else can/should be done. Any help would be appreciated!
