D dana618 New Member Joined Jan 9, 2013 Messages 7 Points 0 Mar 4, 2013 #1 My camera appears to be functional; however when I touch the screen to take a photo I get the following message: "something went wrong while taking this photo" I get this message using the camera and video option. Any ideas????
bosamar Well-Known Member Joined Nov 10, 2012 Messages 1,453 Points 48 My Device RT Mar 4, 2013 #2 Has it ever worked?
OP OP D dana618 New Member Joined Jan 9, 2013 Messages 7 Points 0 Mar 4, 2013 #3 I've had my tablet for about a week and this was my first attempt at using it.
bosamar Well-Known Member Joined Nov 10, 2012 Messages 1,453 Points 48 My Device RT Mar 4, 2013 #4 Open Camera > swipe up from bottom > Camera Options > what do you see? Next, Open Camera > Charms Bar > Settings > Permissions > Web cam & mic ON
OP OP D dana618 New Member Joined Jan 9, 2013 Messages 7 Points 0 Mar 4, 2013 #5 From my options the microphone and webcam is on.
bosamar Well-Known Member Joined Nov 10, 2012 Messages 1,453 Points 48 My Device RT Mar 4, 2013 #6 From the Modern UI select the Camera and then Uninstall. Reboot your Surface, open the Store > Charms Bar > Search > Camera > Reinstall > test it
OP OP D dana618 New Member Joined Jan 9, 2013 Messages 7 Points 0 Mar 4, 2013 #7 Still doesn't work. Do you think a system refresh would help?
bosamar Well-Known Member Joined Nov 10, 2012 Messages 1,453 Points 48 My Device RT Mar 4, 2013 #8 I'd contact support first: Microsoft Surface support | Surface help and how-to | Surface setup and troubleshooting
OP OP D dana618 New Member Joined Jan 9, 2013 Messages 7 Points 0 Mar 4, 2013 #9 Thank You for your help
bosamar Well-Known Member Joined Nov 10, 2012 Messages 1,453 Points 48 My Device RT Mar 4, 2013 #10 I'm sorry I couldn't help you.
ArnoldC New Member Joined Nov 26, 2012 Messages 1,537 Points 0 Location Makati, Philippines Mar 4, 2013 #11 Did you check the destination folder if it is there?
OP OP D dana618 New Member Joined Jan 9, 2013 Messages 7 Points 0 Mar 5, 2013 #12 The problem was resolved. I called Microsoft support and my destination folders were not configured correctly. Thanks for the help.
