Test SSD Speed plugged and unplugged charger
saidgta
i tested SSD speed of my SP4 i5 128GB by HD Tune Software.
there is a big difference between plugged and unplugged charger; but is this Normal?!
Plugged Charger:
Unplugged Charger:
Is it consistently reproducible? How many times did you do this?
Can anyone independently verify these results?
Note that maximum and burst rate speeds are not that different.
There could have been a background process doing something that affected your results.
I tried 4 times. No background process.
Does it really have an effect in your real world use case?
Personally the only time I have noticed a difference in HDD performance on any machine is when using an external SSD versus a mechanical drive. And that too mostly running VM's. YMMV.. do let us know.
May it really have not an effect in real world use, but the problem is:
"Is this deference Normal?!"
