Post Your SP3 Power/Battery/Charging Issues Here
Discussion in 'Microsoft Surface Pro 3' started by leeshor, Jun 21, 2014.
  1. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Lots of issues with not charging or what to use. Post your issues here.
  2. mikeakanice
    mikeakanice New Member
    Jun 21, 2014
    5
    2
    0
    I wouldn't say power issues as much as I would say battery issues. I'm not sure how the reviews and Microsoft are claiming people are getting 9 hours of web browsing. All I've been doing is light web browsing and one note and I can only manage 4 to 4 1/2 hours of battery life. That's with all the updates and brightness only set to 35%. Hopefully this is a bug and something Microsoft will fix very very soon.
    Fabian and Dustin Moffitt like this.
  3. tuchas
    tuchas Active Member
    Mar 22, 2013
    185
    35
    28
    Chicago, USA
    Yes, battery life is surprisingly poor, even after the firmware update. I got about the same - 4 1/2 hours with about 40% brightness.
  4. jnjroach
    Nov 9, 2012
    7,936
    1,879
    113
    Seattle, WA USA
    Other
    I've been using it since 6 AM and have managed 8.25 hours and still have 20% left. I'm using Modern UI IE, Bing News, Tweetium and a few other Modern UI Apps.
  5. kristalsoldier
    kristalsoldier Well-Known Member
    Feb 24, 2013
    2,379
    371
    83
    Yeah...can't complain about battery life either. I spent the whole day (literally 9-5 on the device) updating stuff, installing apps, fiddling around, reading on sites, posting on sites, using OneDrive and Office (mainly Word), reading and replying to email. I still have 48% left.
  6. EMINENT
    EMINENT Active Member
    Feb 18, 2013
    400
    64
    28
    That's fantastic!
    What brightness? Did you modify any settings like having shuffled wallpapers active while on battery?
    I have to have this on. It's one of my favorite features.
  7. kristalsoldier
    Feb 24, 2013
    2,379
    371
    83
    Brightness at around 40%. No shuffling wallpapers. No other settings modified. It's just been over 24 hours since I took the SP3 out of the box so no messing around yet...just putting the device through its paces at the moment.
  8. mikeakanice
    Jun 21, 2014
    5
    2
    0
    How do you know the exact time you are getting on your battery? are you estimating or is there some type of app?
  9. mikeakanice
    Jun 21, 2014
    5
    2
    0
    Same question to you too are you using an app or guessing or what?
  10. ctitanic
    ctitanic Well-Known Member
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Please, run this:
    powercfg /batteryreport /output %USERPROFILE%\Desktop\battery_report.html
    That will help to find the cause.
    wayne likes this.
  11. kristalsoldier
    Feb 24, 2013
    2,379
    371
    83
    No app. just observation. I started with 100% exactly AT 9am today. It is now 8:51pm at my location and the battery icon report 19% at which time I plugged the SP3 into the mains. This means I got 11:51 minutes of battery time. I would knock off 2 hours because my observations are just that - so that would account for the error margin, which still leaves me at 9 hours of runtime, which is very close to what MS predicts for this device.
    Edit: I would also second what ctitanic recommends - run that command and see what the report throws up.
    1 person likes this.
  12. jnjroach
    Nov 9, 2012
    7,936
    1,879
    113
    Seattle, WA USA
    Other
    No my son woke me up at 5:45 AM today, by the time I had my morning routine and coffee when I sat down it was 6 AM, I started reviewing what happened over night on my SP3 (which was at 100%), at 2:15 PM I posted the above which was 8.25 Hours on battery, I finally plugged in at 10% which was at 3:45 PM so I ended up with 9.75 Hours with 10% left under normal use...
microsoft sp4 lader
microsoft surface battery and charger issues fa
no battery issue sp3
sp3 battery download
sp3 battery drain after install windows 10
sp3 drains faster than charging when playing games
sp3 firmware update charging
sp3 not charging
surface pro 3 75 percent not charging
tabletmark sp3
