Surface Pro 3: Six Months Later
Discussion in 'Microsoft Surface Pro 3' started by benjitek, Dec 12, 2014.
  1. benjitek
    benjitek Active Member
    Jan 7, 2014
    622
    70
    28
    SPro2
  2. sharpuser
    sharpuser Super Moderator Staff Member
    Aug 20, 2013
    3,406
    1,115
    113
    Pacific Northwest & China
    Surface Book
    A fair review, I think.
    Author Paul Thurrott's opinion:
    - Kickstand
    - Weight and thickness
    - Can replace laptop (and desktop via docking station)
    - Software bundled is Microsoft Windows only. No 'crapware'.
    Dislikes:
    - Needs second USB
    - Small screen
    - Ecosystem only now emerging
    VickiFL likes this.
  3. GreyFox7
    Jul 27, 2014
    6,789
    1,355
    113
    If it had a second USB then it would need a bigger battery and people would complain with two passive hubs plugged in driving a suite of USB devices the battery life is too short. then it would have to be thicker and heavier... with an even bigger battery. There's no winning only losing. ;)
    kristalsoldier and sharpuser like this.
  4. sharpuser
    Aug 20, 2013
    3,406
    1,115
    113
    Surface Book
    Well said, @GreyFox7. I think my Surface Pro 3 has found a 'sweet spot'. :rolleyes:
  5. markusbeutel
    markusbeutel Member
    Aug 18, 2014
    148
    22
    18
    If they make a legitimate keyboard, you could easily fit an extra usb in there, as well as an extra battery...
  6. jnjroach
    Nov 9, 2012
    7,765
    1,838
    113
    Seattle, WA USA
    Surface Book
    Unless the Surface Team has a complete change of heart and direction it ain't going to happen, from an engineering perspective they have written off the idea of a solid keyboard attachment, they prototyped a few designs and it brought nothing to the table. The SP3 is a Halo Device that is designed to point to a specific direction in Windows Computing.
    Microsoft is perfectly content on letting the OEMs to create devices that have hints of the SP3 but offers more legacy use cases.
  7. Moonsurface
    Moonsurface Super Moderator Staff Member
    Jul 13, 2014
    836
    202
    43
    UK
    I'm happy with the way Microsoft have designed this device, its fully met my needs and also met needs I didn't even know I had, yes extra ports would be nice but I think the way it's designed is pretty optimal using the tech available at the moment while still keeping the size/weight. I like that it's so thin and light, it's VERY positive thing for me, and adding extras would take that away somewhat I'm sure.
    . As said I'm sure MS are happy that OEMs to do their own take on the Surface, that was their idea for it after all to show other manufacturers what is possible with this sort of hardware tech and windows 8..
    RémiM likes this.
  8. hughlle
    Jul 7, 2014
    3,085
    465
    83
    Why would an extra usb port mean a need for a bigger battery? Isn't it a case like with everything (e.g screen brightness, power use) that if you use it in such a manner, battery life will be effected. How does having a second port automatically mean a need for a bigger battery. You'd just expect to get slightly less run time if you were to use both.
  9. jnjroach
    Nov 9, 2012
    7,765
    1,838
    113
    Seattle, WA USA
    Surface Book
    It wouldn't need a bigger battery but another port if on a dedicated bus (i.e a real additional USB Port) would require more power thus either would need a bigger battery or have less battery life. An additional port but not on a dedicated bus would (i.e converting the existing USB Port into a Hub with to connections) would exasperate the current issues people face...
  10. Moonsurface
    Jul 13, 2014
    836
    202
    43
    UK
    exasperate or exacerbate... or very possibly both... lol :D
    Alex_SP3 and GreyFox7 like this.
  11. jnjroach
    Nov 9, 2012
    7,765
    1,838
    113
    Seattle, WA USA
    Surface Book
    Gotta love auto correct;)
    GreyFox7 and Moonsurface like this.
  12. hughlle
    Jul 7, 2014
    3,085
    465
    83
    Why would it use more power if you're not using it? Surely if nothing is plugged in, no additional power is being used.
six month with surface
surface 3 review 3 monts later
surface pro 3 6 months later
surface pro 3 after minths
surface pro 3 cpu refresh
surface pro 3 months after
surface pro 3 review 1 month later
surfce pro 3 after 6 months
