Cowboy
- Joined
- Feb 17, 2013
- Messages
- 62
- Points
- 0
I bought a BobjGear USB 3 to RJ45 SuperSpeed Gigabit Ethernet Adapter. It is a little pricey ($30) but it is built like a tank. The short cable is re-enforced at both ends and the plastic piece that holds the Ethernet jack is thick and well made. I have really had it with cheap USB devices that fall apart after a few weeks use. But yes I did have to install the drivers that came with it to make it work but I didn't consider that a hardship. Now maybe if I were doing 50 of them.....
