Bootloop with red stripe and padlock
Sprelle
A friend asked me to have a look at his SP4, as it bootlooped.
As you can see from the pictures, this is the ONLY screen it is possible to conjure up.
I have tried holding down the power button for a minute, and restarting whilst holding volume up,
but no other screen is coming forth. I have also tried volume down.
I have made a recovery drive, and stuck it in the USB-port, but after a few feeble blinks on the
thumb-drive LED, nothing happens, and I am back with this screen.
Is the machine fried for good, or can anyone help??
I have tried 3 different variants of recovery stick, even installed a win10 iso with rufus.
It always returns immediately to this screen.
Only when I tried to boot it off an unbuntu-stick did it hesitate for a second before returning to the 'default' screen,
I have also tried all combinations of power, + volume, - volume etc.
Your help is much appreciated :-)
Morten
Did you change Secure Boot setting s in UEFI? That is what the Red-bar and Padlock usually signify...
I cant get the machine to boot into UEFI at all, just this screen no matter what I do or what combination of keyes I push....
Shut down completely, then holding volume up rocker press the power button, do not let go of the volume rocker until the Surface Logo papers, that should get you into UEFI. If that doesn't work reach out to support.
So, you have even seen this before?
When the UEFI Keys have been changed or Secure Boot has been disabled. There was one insider build a while ago that had expired UEFI Keys that could cause this as well.
I had this issue with a Surface Pro 3 in an Enterprise environment and all I did was connect the Surface Pro 3 to a Surface Dock and PXE boot to the Enterprise Windows 10 image and it successfully booted to Windows 10 after the image completed. Hope this somehow helps.
