Direct Shuts Down less than 2-3 seconds after Low Battery Warning - Surface Pro 3 (Windows 10)
hannytyo
Jakarta, Indonesia
Hi,
I own a Surface Pro 3 running Windows 10 (Version 1703).
Windows 10 now directly shuts dow (hibernates) my Surface Pro 3 only less than 2-3 seconds after Low Battery Warning.
FYI, I use Battery X app, to monitor my battery. So far my discharge rate is between 15-20%.
So what's wrong?
Thanks!
At what % is your machine set to give you the warning? I seem to recall this happened on mine and i just changed the warning to 20%
Hi, warning at 10%. Usually it will take around 5-7 minutes before SP3 shuts down. For the last 2 weeks, I happened to use my SP3 twice until this warning, and it just shut itself down.
