Hello from Germany, maybe you can help me here, i have a problem with my SB2, if the charger is connected after 1-2 min my mouse is jumping and jerky. If i disconnect it , it directly go smoth again, if i put it in again it is directly jumping and jerky. If I pull out usb from my mouse and put it in again it goes smooth again for 1-2 min. But no problems with Touchpad.
Also if the connector is plugged in and i move my mouse there come sounds from my SB2 but not from the speaker it makes sssssst i move mouse sssst i dont move its not making noises. Also this problem with Touchpad, if i pull out the connector this problem is away, if i connect charger this problem is there again.
Edit : The noise comes also if the connector is disconnected but its not so loud in Microsoft Edge it gets louder again.
What can I do ? I try different mouse etc. it must be a problem with Surface or the charger. Should i try a new charger ? You no this problem ?
Thank you very much.
