Bennyhill43
- Joined
- Nov 17, 2015
- Messages
- 7
- Points
- 3
- My Device
- Surface Book
Not sure if anyone else is having this issue but my SB seems to turn itself on without my input. I can turn it completely off , shutting it down by the normal Windows method. Only to find it running when I remove it from its case. I'm using a Solo 13 inch case that fits perfectly even with the pen attached. On several occasions I open the case and find one very hot SB that's powered itself back on. My first thought was maybe something is hitting the power button but the problem has occurred a couple of times with the SB sitting on the desk and not in the case. I don't worry to much about that scenario as I do when the unit is in the case and not able to breath.
Any help would be appreciated.
