Solved Surface not starting
nanoy
Hi, always when i turn on my surface pro 3 not start, it's blocked on surface screen, so i turn off, press power button for 30 seconds and then it's start! Why i can always do this procedure when i use it?
Thank you
Hello, and welcome to the forum.
Are you using the latest Windows 10?
Have you visited the "Account" settings to make your sign on options?
Yes i use windows 10
What do you say?
Thank you
Please explain what you mean "blocked on surface screen". What is the message you see?
Try a "restart" while depressing and continuing to hold SHIFT key. Troubleshoot your Surface.
When i do this: Try a "restart" while depressing and continuing to hold SHIFT key. Troubleshoot your Surface.... Surface restart but block at first image where appear surface
So if i want restart i i turn off, press power button for 30 seconds and then it's start!
I dont know why!
I've experienced this a long time ago, but windows updates soon fixed it.
Updates all installed, i post an image for a firmware problem? Can it cause my problem?
Thank you
Yes, this could cause your problem.
Uninstall, and search for new driver on your Surface.
i uninstall and search for a new driver, when i restart for install it surface not start and blocked on surface start screen , same problem... i press power button to power off and then 30 seconds for restart, when windows start again a messages say: not possible install update and i have firmware error again
