Surface pro running slow when connected to the internet
conan
Hi,
I have recently updated and since then my surface pro slows right down when I am connected to the internet. If I am not connected to the net it runs as normal but once I connect it slows down until it is barly useable. I don't even need to be using the net, it just needs to be connected.
I have plenty of space on my surface so that's not the issue. before updating it was running fine while connected to the internet. I tried updating to 8.1 but that didn't help.
Any help would be great.
Thanks!
Do you have many apps that are internet linked??Try closing all running apps and check performance.
IF you disconnect from a wireless network does the surface speed up noticeably?
Due to any one of the following reasons your internet gets slow down;
1. Local network is overloaded
2. Malware or scareware on end users computers
3. Bad connection
Use the following tips to increase your internet speed :
1. Clear cookies from your browser
2. Close unwanted background tasks when you are working with the internet .
3. Scan your internet by using standard Anti-virus software
4. Reset your modem and reconnect with the internet.After that , you can test your internet speed by using Scanmyspeed.com to get better results .
