Surface5280
- Joined
- Dec 6, 2012
- Messages
- 24
- Points
- 0
The camera system is a 2.4ghz system, (but then again what isn't anymore?) I was using the surface while the video monitor was right next to the surface and it wouldn't connect to the internet until I turned off the monitor? I turned it back on and it was having issues with the connection to my wireless router. I changed the channel on my router to see if that helps out, because I have no idea what channel the video monitoring system operates on, and thought maybe there was a conflict on the channels or something?
Anybody have any insight into this problem? Also does the surface operate on the 5ghz range as well? If so I might have to go get a new wireless router that broadcasts in the 5ghz range, because it seems like the 2.4ghz frequency is clogged up with everything operating on that frequency.
Any thoughts, suggestions, comments welcome.
Thx
Thx
