docking station conflicts with wifi - kensington sd3000v / sp4 - help!
Maverelli
Hi all,
I recently purchsed an SP4 ... and whenever i plug in my kensington usb docking station (for use of second display) it breaks my internet/wifi connection!
I really cant understand it... its a talktalk wireless router
I tried disabling the ethernet adapter for the kensington hub in device manager but this does not work (it seemed to work on my other laptop, also running windows 10 where i had a similar issue of intermittent wifi)
Maybe it just an unlucky driver conflict (I tried updating the drivers for the hub).
I really dont want to fork out for the surface dock because of this madness.
any help would be really appreciated ; )
If it's a USB3 hub, you should be able to solve the problem by substituting a USB2 hub or using a 5 GHz WiFi connection. This guy had the same problem and solved it:
