Hidden FN keys for Screenshot, Print Screen, and Screen Brightness. What else is there?
San Antonio, TX
I feel like I just discovered the Surface Pro 3's type cover keyboard dirty little secret's, using unmarked FN shortcuts. I almost feel like I wish this was a sticky as it could have saved me countless time wasted using the on-screen menu, had I known sooner. These are what I found so far scattered in many different post throughout this forum.
Print Screen
FN + SPACEBAR
Screenshot (Saved in Pictures folder)
FN + WINDOWS KEY + SPACEBAR (in this order)
Screen Brightness
FN + DEL = Screen Brightness UP
FN + BACKSPACE = Screen Brightness DOWN
What other hidden FN key type cover shortcuts are there that us Surface Pro owners should be aware of to save time, and also very useful that I can add to this list? Maybe a volume UP and volume DOWN shortcut? Yes, I know, but many times I really don't feel like lifting my arm to hit the volume keys!
Print Current Window Only
FN + ALT+ SPACEBAR
Page Up
FN + ARROW UP
Page Down
FN + ARROW DOWN
Home
FN + ARROW LEFT
End
FN + ARROW RIGHT
Function Keys Active / Inactive
FN + CAPS
Thanks for the tips guys! I just copy/pasted all these in my OneNote for reference. I knew of the screen brightness and one of the print screen brightness, glad there were more!
The screen brightness one is GOLD Jerry!
I would love if they had an FN function to toggle WiFi On/Off. Would make the "limited" connectivity issue a lot easier to deal with...
Too bad a hardware or Fn key is not already available to to that, but...
There is a sweet little utility here to toggle on and off 'Airplane Mode', which can be assigned a shortcut key.
I posted an alternative here: http://www.surfaceforums.net/thread...-tile-you-really-need-windows-8-and-8-1.8446/
I wish there was hidden keys to raise and lower the volume. I don't always find the volume rocker convenient.
I just tried SharpColorado's suggestions above for airplane mode toggles. I used the utilities he recommended and assigned shortcuts to them. Here is what they look like on my Start Screen:
Tiles are resizeable, too.
I assigned keyboard shortcuts using the " { " and " } " symbols, since they look like aircraft. The shortcuts automatically revert to [ and ], but that works fine.
So now, I can either use the tiles, or toggle Airplane Mode with
Ctrl+Alt+{ - off
or
Ctrl+Alt+} - on
