One note problem with moving selected material
Modification
Heres a short video clip of the problem.
As you can see when I select text and I move it to another location, the selected material changes. You can see that there is now a space after the first couple lines that were not there before.
This does not happen every time. At the moment though, I can move this selected text is any direction and it'll do the same thing. Press back, rinse and repeat. If I re-select it and I try to move it again, same thing.
So at the moment I CANNOT move it without getting that space in between in the end.
Does this happen to anyone else and is there a fix for this?
Try selecting the whole ink, right click, then "Treat Ink as Drawing"
